70 Personne(s) en ligne (47 Personne(s) connectée(s) sur Forum)
Invité(s): 70
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000115 - SET NAMES 'utf8'
0.000983 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'c848bdafae0c3f9be3bb397ef6fa59e9'
0.000133 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000295 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 318861
0.000083 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000063 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000312 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000329 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000519 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000361 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 318861
0.000044 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000874 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000169 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000403 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001164 - UPDATE online SET online_updated=1793908584, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000717 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001040 - UPDATE online SET online_updated=1793908584, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000261 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000858 - UPDATE bb_online SET online_updated= '1793908584', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000185 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000518 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('170.168.28.217','207.46.13.127','193.151.191.206','185.191.171.5','83.25.228.167','52.167.144.156','201.207.239.31','104.205.80.210','40.77.167.235','185.191.171.3','62.107.16.165','130.49.115.203','185.191.171.15','85.208.96.199','154.110.187.136','73.155.200.250','130.49.115.168','66.249.64.7','190.62.84.80','94.122.146.109','85.208.96.211','181.230.68.49','177.91.82.42','88.162.13.6','31.134.15.200','202.46.62.38','79.126.113.226','151.244.152.177','197.221.251.55','41.158.199.196','77.243.26.99','216.73.216.84','146.19.91.104','185.191.171.9','209.212.210.98','2.125.42.76','79.106.215.227','90.215.42.239','186.91.18.171','41.143.5.147','5.175.146.252','77.98.26.42','157.55.39.195','77.249.56.215','202.46.62.117','104.165.74.239','185.191.171.2') )
0.000172 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000279 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000199 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000172 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000075 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000019 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000020 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000187 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000104 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
0.000129 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 63
Usage de la mémoire: 10085536 bytes
Module display a mis 0.092 seconde(s) pour charger
Page rendering a mis 0.067 seconde(s) pour charger
