89 Personne(s) en ligne (54 Personne(s) connectée(s) sur Forum)
Invité(s): 89
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000105 - SET NAMES 'utf8'
0.001336 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0ec609c39b97ad0da51197507f013be9'
0.000253 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 314575
0.000081 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000041 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000199 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000144 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000101 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000387 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 314575
0.000091 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.001446 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000132 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.006772 - SELECT * FROM groups
0.000161 - SELECT * FROM bb_forums ORDER BY forum_order
0.000487 - UPDATE online SET online_updated=1793908458, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000176 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000723 - UPDATE online SET online_updated=1793908458, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000167 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000798 - UPDATE bb_online SET online_updated= '1793908458', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000602 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('37.65.29.118','185.191.171.5','74.125.210.195','46.176.153.53','202.46.62.106','155.212.109.49','194.77.192.125','104.205.80.210','185.191.171.3','62.107.16.165','185.191.171.7','38.9.221.237','79.179.23.116','92.71.9.155','179.6.23.166','66.249.70.192','188.150.227.167','185.191.171.10','130.49.115.168','66.249.64.7','190.62.84.80','94.122.146.109','85.208.96.211','181.230.68.49','177.91.82.42','88.162.13.6','31.134.15.200','202.46.62.38','79.126.113.226','151.244.152.177','93.177.119.164','197.221.251.55','41.158.199.196','216.73.216.84','217.74.152.235','66.249.70.193','79.117.117.128','167.59.173.238','170.245.1.62','90.215.42.239','186.91.18.171','41.143.5.147','83.167.40.95','5.175.146.252','62.194.37.24','128.127.120.23','185.191.171.16','77.249.56.215','176.28.174.224','202.46.62.117','195.240.169.12','104.165.74.239','185.191.171.2','84.30.40.43') )
0.000192 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000130 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000130 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000211 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000086 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000024 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000040 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000021 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000143 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10079128 bytes
