98 Personne(s) en ligne (74 Personne(s) connectée(s) sur Forum)
Invité(s): 98
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000107 - SET NAMES 'utf8'
0.000966 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '5002220af20696bd03b8a2da675a2325'
0.000115 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000247 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 319109
0.000074 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000088 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000214 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000103 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000029 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000334 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 319109
0.000253 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000188 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.001368 - DELETE FROM online WHERE online_updated < 1793906676
0.000232 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000454 - UPDATE online SET online_updated=1793906976, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000283 - SELECT * FROM online
0.000194 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000587 - UPDATE online SET online_updated=1793906976, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000177 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000460 - UPDATE bb_online SET online_updated= '1793906976', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000183 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000869 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.9','31.134.14.81','180.148.4.209','45.164.32.143','201.225.243.189','103.185.25.11','41.109.60.196','162.220.96.239','85.208.96.205','147.235.197.197','85.208.96.206','190.183.19.63','168.232.225.233','77.234.249.64','105.110.204.203','45.10.167.104','194.246.88.104','194.61.89.114','90.179.7.60','185.191.171.11','77.167.197.63','89.85.202.97','124.29.247.114','79.243.120.222','2.101.129.109','177.47.169.42','86.234.162.3','66.249.64.6','193.142.38.251','85.208.96.209','109.81.90.50','186.22.245.4','202.157.191.196','157.22.72.169','92.176.148.62','195.81.117.250','138.97.160.107','216.73.216.84','92.71.23.137','197.234.87.219','78.82.191.68','92.97.109.139','93.107.124.245','84.122.229.149','92.209.238.65','31.134.4.36','76.142.203.137','133.123.101.183','178.143.191.224','95.215.106.232','92.109.217.123','217.62.192.189','206.85.1.113','190.5.45.240','81.204.188.244','185.191.171.16','78.48.16.235','37.179.94.54','85.208.96.210','179.191.237.11','95.5.70.51','109.92.158.14','62.233.39.56','154.20.48.227','85.117.228.153','186.179.68.20','185.229.54.167','213.188.176.57','82.215.102.88','45.167.1.27','104.165.197.43','185.191.171.13','167.250.133.91','192.101.65.13') )
0.000193 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000207 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000094 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000246 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000694 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000072 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000042 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000025 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000081 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000130 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10068536 bytes
