137 Personne(s) en ligne (97 Personne(s) connectée(s) sur Forum)
Invité(s): 137
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000157 - SET NAMES 'utf8'
0.002491 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001157 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'ba27e2a06c1b0f626b69c738724c921f'
0.000109 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000345 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 330703
0.000069 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000047 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000290 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000182 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000046 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000484 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 330703
0.000279 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000778 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000244 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000263 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000445 - UPDATE online SET online_updated=1793910017, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000338 - SELECT * FROM online
0.045331 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000526 - UPDATE online SET online_updated=1793910018, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000242 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000177 - UPDATE bb_online SET online_updated= '1793910018', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000318 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001710 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','86.41.130.37','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','116.96.78.115','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','46.128.8.6','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','178.43.244.182','109.242.90.144','157.22.72.59','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','157.55.39.204','45.65.167.138','109.245.151.204','38.74.245.120','109.196.67.205','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','186.91.18.171','106.73.159.193','90.233.195.169','41.83.45.142','27.79.121.243','212.93.153.39','188.151.133.137','185.191.171.11','109.81.12.155','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','173.33.114.42','190.145.240.183','14.231.252.236','185.191.171.13','199.201.92.59','85.208.96.209','216.73.216.244','66.9.171.28','200.180.238.253','177.70.165.214','85.208.96.193','91.82.240.128','85.217.249.150','152.249.11.244','90.14.5.65','93.117.164.200','201.4.71.213','213.232.122.23','85.208.96.206','185.244.154.87','190.99.23.153','102.38.1.172','155.133.78.47','40.77.167.235','66.249.70.192','138.84.47.240','134.249.12.43','201.180.185.250','191.108.51.228','79.106.215.227','40.77.167.121','2.215.146.133','103.181.127.136') )
0.000240 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000354 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000076 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000265 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000038 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000029 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000034 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000034 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000082 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000032 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10084120 bytes
XOOPS a mis 0.462 seconde(s) pour charger
XOOPS Boot a mis 0.067 seconde(s) pour charger
XOOPS output init a mis 0.123 seconde(s) pour charger
Module display a mis 0.163 seconde(s) pour charger
Page rendering a mis 0.084 seconde(s) pour charger
