102 Personne(s) en ligne (72 Personne(s) connectée(s) sur Forum)
Invité(s): 102
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000125 - SET NAMES 'utf8'
0.001032 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '17a86e31f87686ef3b4caf26e3aed282'
0.000279 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 313354
0.000081 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000088 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000034 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000252 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000101 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.000340 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1 AND post_id < 313354
0.000046 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000493 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.000771 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000193 - UPDATE online SET online_updated=1793910853, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000239 - SELECT * FROM online
0.000267 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000118 - UPDATE online SET online_updated=1793910853, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000138 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000441 - UPDATE bb_online SET online_updated= '1793910853', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000730 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.93','66.249.70.202','170.247.193.112','202.46.61.99','202.46.62.73','66.249.64.7','192.177.138.194','41.74.138.65','193.202.87.184','85.208.96.203','185.191.171.18','157.22.101.44','45.148.212.56','213.194.144.206','23.230.22.247','92.17.71.38','45.88.13.80','37.214.3.24','176.202.190.61','176.64.10.248','77.46.156.175','209.198.130.13','147.78.161.255','190.88.244.219','86.44.12.211','83.182.100.110','190.252.174.6','102.220.14.200','185.132.251.90','102.64.161.123','87.9.211.139','202.46.61.64','83.97.116.156','88.97.197.159','85.208.96.211','85.208.96.202','170.168.173.236','217.204.62.227','187.110.233.106','90.15.245.154','193.32.76.91','118.179.39.1','202.46.61.131','103.135.253.194','95.70.223.222','65.92.188.138','88.242.203.31','216.73.216.244','90.163.41.71','93.172.169.71','119.93.153.253','148.222.119.171','154.110.228.36','176.6.10.197','154.39.145.191','165.165.116.70','172.59.208.181','185.191.171.14','202.46.62.13','157.22.72.132','37.133.166.89','112.201.130.123','74.244.163.203','185.154.3.182','152.232.176.97','37.236.180.234','93.152.77.190','31.134.7.113','83.105.143.155','185.168.30.221','77.220.194.60','85.208.96.198') )
0.000170 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000128 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000100 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000265 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000074 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000077 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000022 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000114 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000027 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Total: 63
Usage de la mémoire: 10073608 bytes
