155 Personne(s) en ligne (123 Personne(s) connectée(s) sur Forum)
Invité(s): 155
« 1 (2) 3 »
Post(s): 530
Post(s): 70
Coucou !
A bientôt
Nico
De Béthune 62
Post(s): 232
Sa ne peut pas fonctionner :)
Post(s): 530
De Béthune 62
Post(s): 232
De Béthune 62
Post(s): 232
Post(s): 530
Merci a plus
sur le bon coin 190 euros
ici
Post(s): 70
Coucou,
A bientôt,
Nico
GT Performance
01 64 11 35 66
Post(s): 511
Post(s): 511
Post(s): 70
Nico // GT Performance
« 1 (2) 3 »
0.000195 - SET NAMES 'utf8'
0.000055 - SET SQL_BIG_SELECTS = 1
0.001243 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '627e3ff02918fd0066bac591b2e26536'
0.000652 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000336 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000057 - SELECT * FROM bb_forums WHERE forum_id = 22
0.000038 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '22' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000284 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 15596
0.000029 - SELECT * FROM bb_topics WHERE topic_id=15596
0.000611 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=15596 AND approved = 1
0.001200 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=15596 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000272 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =15596
0.006224 - SELECT * FROM groups
0.000106 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000389 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001483 - UPDATE online SET online_updated=1793906241, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000423 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001297 - UPDATE online SET online_updated=1793906241, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000216 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000727 - UPDATE bb_online SET online_updated= '1793906241', online_forum = '22', online_topic = '15596' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000351 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001816 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.13','109.174.150.40','31.216.91.238','45.132.187.214','52.167.144.141','90.46.141.250','84.122.229.149','189.162.184.152','185.191.171.16','46.185.191.197','5.31.195.185','87.56.23.217','166.114.128.28','154.246.32.94','62.204.49.250','185.191.171.6','185.77.223.189','86.45.209.138','162.141.97.158','185.195.185.78','188.187.15.75','87.197.92.130','87.56.23.39','109.174.146.87','102.0.31.4','105.113.102.255','85.208.96.197','105.108.219.242','115.76.126.43','155.4.125.107','185.191.171.2','102.253.64.25','37.131.43.187','46.254.47.67','102.212.197.190','105.107.216.215','46.34.249.163','185.191.171.17','80.32.2.178','103.59.38.33','185.135.69.82','102.88.169.178','66.249.70.194','66.249.70.202','94.16.41.116','197.234.87.219','190.174.110.142','191.23.75.89','186.251.6.179','5.134.86.124','66.249.70.201','188.241.101.242','85.208.96.206','94.205.209.188','185.217.190.156','57.134.176.141','190.57.181.1','181.131.74.254','38.211.32.164','187.112.13.131','196.238.219.122','195.81.136.135','66.249.70.192','201.4.87.28','169.224.12.76','45.189.63.27','102.66.145.29','116.204.166.57','90.36.122.235','45.133.113.204','157.55.39.53','105.110.204.203','46.149.92.13','167.253.17.66','195.81.154.173','66.249.70.195','216.73.216.84','46.162.203.26','92.41.50.111','177.115.3.168','24.16.219.183','187.190.11.189','66.249.70.197','197.188.227.96','66.249.70.193','66.249.64.6','181.87.167.147','77.207.54.11','185.191.171.10','45.234.16.166','157.22.44.123','37.67.46.5','185.81.144.203','185.191.171.4','105.74.0.46','45.67.171.92','83.134.25.230','66.249.70.196','185.201.139.202','68.167.156.165','85.208.96.203','191.242.55.33','185.190.132.139','202.46.61.76','181.115.174.28','209.212.220.178','41.193.163.152','85.208.96.207','185.191.171.3','77.46.175.227','62.65.228.98','192.101.65.200','78.181.17.152','181.79.88.199','103.203.37.35','66.249.70.199','85.208.96.209','196.189.57.103','66.249.64.8','66.249.64.7','190.110.179.61','212.119.47.150','45.147.8.182') )
0.000713 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '15596'
0.000271 - SELECT * FROM bb_online WHERE (online_topic = '15596' AND online_uid <> '0')
0.000602 - SELECT * FROM `users` WHERE uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000280 - SELECT * FROM bb_online WHERE online_uid IN (1315,1310,841,3148,479,4785,8090,68,1779)
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
0.003045 - SELECT groupid FROM groups_users_link WHERE uid=1310
0.000130 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000096 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000229 - SELECT groupid FROM groups_users_link WHERE uid=3148
0.000361 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 530 AND rank_max >= 530 AND rank_special = 0
0.000207 - SELECT groupid FROM groups_users_link WHERE uid=479
0.000059 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 70 AND rank_max >= 70 AND rank_special = 0
0.000051 - SELECT groupid FROM groups_users_link WHERE uid=4785
0.000054 - SELECT groupid FROM groups_users_link WHERE uid=8090
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 304 AND rank_max >= 304 AND rank_special = 0
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=68
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 511 AND rank_max >= 511 AND rank_special = 0
0.000128 - SELECT * FROM bb_categories WHERE cat_id = 2
0.001330 - SELECT post_id FROM bb_posts WHERE topic_id = 15596 AND pid = 0
Usage de la mémoire: 10068288 bytes
XOOPS a mis 0.490 seconde(s) pour charger
XOOPS output init a mis 0.122 seconde(s) pour charger
Module display a mis 0.184 seconde(s) pour charger
Page rendering a mis 0.150 seconde(s) pour charger
